The alt is an SI series, as wired it will be fine (reversing the amp gauge is better than getting used to seeing it work backwards) The starter relay is wired with the S small terminal going through the activation coil inside then to ground (mounting bracket), 7 ohms is about right. It is the source of magnetism that moves the plunger and pushes a copper disk against three contacts, connecting them together as long as the S is energized. The big terminal to the battery is the source of electricity to the disk. The other big contact (now connected) is supplying the starter with high current energy. The last contact is smaller, it is connected to the I terminal and that is connected to the ignition coil. It is isolated to prevent the ignition from trying to start the engine, but allow the relay to give bypass voltage to the ignition when starting. Thousands of ohms would be expected, or no conduction. I hope this explains it. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
