Posted by CNKS on October 31, 2012 at 19:01:48 from (216.144.104.128):
In Reply to: Re: Gear Oil posted by NEKS on October 31, 2012 at 18:41:38:
That tractor is a 140, essentially the same tractor as the 1939 Farmall A, with some upgrades. Those transmissions are known to be noisy from the factory, the best oil to use is 80W140 or even straight 140 in a warm climate it is not too heavy. The only IH tractors that need hyd oil are the ones with a torque amplifier, and those have gear clash when shifting due to the equivalent SAE 10 wt, 20 wt or 10W30. There are still 10s of thousands of Farmall letter series tractors using gear oil -- I have 5 of those and 2 with TA's that use hydraulic fluid.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
