Re: Gear Oil
Posted by gene bender on November 01, 2012 at 03:09:27 from (207.177.56.85):
In Reply to: Re: Gear Oil posted by NEKS on October 31, 2012 at 18:41:38:
Those old tractors used 90wt no TAs or hy pumps in those trannys.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
