jump-starting 6 volt battery
Posted by Ricky on October 21, 2000 at 11:25:37 from (205.188.197.52):
Is it safe to use jumper cables to start a 6-volt battery (Super A) hooked up to a 12 volt battery(my truck) and if so do you still use pos to pos even though the 6 volt has a pos ground.
Thanks
Post A Followup
: Re: jump-starting 6 volt battery
