Super Governor
Posted by Bohn Super C on November 01, 2012 at 09:12:16 from (209.40.218.124):
Last fall I bought a 1954 Farmall Super C tractor and I don't believe the governor is working properly. I bought a 6 foot finish mower for the three-point hitch, and when I was using it this summer, every time I push in the clutch the engine revs way up high, so I've been pulling back on a throttle before I push the clutch in to get by for now. Also when I bring the throttle back down to idle it still idles quite fast, and I grab the link that goes from the governor to the carburetor to idle it down slower but then it usually stalls out. Also there is a fuel cap on the governor housing which I have not seen on any other Super C tractor. The cap on the governor housing reads buy clean fuel, keep it clean. When looking at the governor housing it it does not look like anything's been fabricated, that it was made that way from factory. Has anybody seen anything like this before?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
