Re: Super Governor
Posted by mkirsch on November 01, 2012 at 12:35:57 from (64.80.110.75):
In Reply to: Super Governor posted by Bohn Super C on November 01, 2012 at 09:12:16:
Your Super C probably has a governor housing off a 240 or 340's engine.
That is the oil fill location on those tractors. On a Super C you fill through the breather sticking out the middle of the hood.
Racing engine indicates a stretched, broken or missing spring in the governor.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
