Re: farmall 300 fouling plugs
Posted by greg potts on November 03, 2012 at 14:25:00 from (74.98.229.49):
In Reply to: farmall 300 fouling plugs posted by greg potts on November 03, 2012 at 13:41:17:
Hey thanks for the info, black smoke still happens when air cleaner is disconnected, also checked choke it is wide open, thermostat is installed, engine gets warm you can touch block with hand and feel it is somewhat hot to the touch
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
