Re: H Compression Ratio readings
Posted by kossuth on November 04, 2012 at 19:58:22 from (108.8.12.247):
In Reply to: H Compression Ratio readings posted by c1802362 on November 02, 2012 at 20:00:33:
Might be worn valve guides. Wouldn't show up in your compression numbers but you would have oil "slobber" build up on both the intake and exhaust valve ports of the head where the manifold bolts to. Those motors from the factory didn't have valve seals so it's possible it's alittle worn.
