H Compression Ratio readings
Posted by c1802362 on November 02, 2012 at 20:00:33 from (72.221.74.28):
Checked my '41 H's compression numbers tonight.
Cold cranking yielded the following (gauge readings in psi)
Cyl 1: 90
Cyl 2: 93
Cyl 3: 88
Cyl 4: 85
Does anyone have any opinion as to if this is normal or low?
The tractor's S/N ends in X3, which I understand is distillate, but
I've been running it for years on gas
Art
