Re: C-123 C motor rear main seal.
Posted by CharlieNJ on November 05, 2012 at 12:01:14 from (76.117.68.151):
In Reply to: C-123 C motor rear main seal. posted by Joshua Rod on November 05, 2012 at 10:19:34:
Joshua, you need the flywheel off the crankshaft to service that rear main. So you do it on the engine stand or the bench.
Regards,
Charlie
