Re: farmall m electric problem
Posted by mkirsch on November 06, 2012 at 05:17:52 from (64.80.110.74):
In Reply to: farmall m electric problem posted by bill engel on November 05, 2012 at 16:41:41:
You definitely should get the alternator checked.
The meter pegging to the right tells me that the voltage regulator in the alternator has fried. The high voltage in the alternator burned out your coil, or the ballast resistor, or the condenser.
I suspect if you just replace the coil/resistor/condenser/etc, and try again, you will be replacing ANOTHER coil/resistor/condenser very soon.
