Posted by bill engel on November 05, 2012 at 16:41:41 from (174.59.75.166):
I have a M farmall which I converted to 12 volt several years ago. It has the delco alternator, a 6 volt coil, and a ballast resistor..and has been working fine all along. Today, I started the tractor, warmed it up, and ran up the throttle til the ammeter went into charge mode. I turned on the headlights, just to see if they still worked. They did, but then i noticed the ammeter pegged all the way to the right, and the engine stopped running. I have no spark coming out of the coil. The headlights still work. I do have proper continuity throughout the circuit. The resistance across the ballast resistor is 0.00. According to the spec, it should be around 1.5 ohm. Did I perhaps fry the resistor, and or the coil? Thinking about bypassing the resistor, and installing a 12 v coil. Any advice, I would greatly appreciate.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
