Re: 300 Utility hydraulic questions
Posted by RPM1941 on November 10, 2012 at 11:24:13 from (173.23.76.185):
In Reply to: 300 Utility hydraulic questions posted by 300 dave on November 10, 2012 at 10:36:29:
I would deal with the contaminated fluid right away if you are in a cold area or tractor is outside in freezing or below temp. The water in the oil will freeze up and starve the pump, could damage it badly. It needs to be changed yearly, it will hold some in suspension ok but has chemicals to make it white when its past its limit.
