300 Utility hydraulic questions
Posted by 300 dave on November 10, 2012 at 10:36:29 from (74.32.160.84):
Hi gang,
My 300 utility has a hydraulic problem, hoping someone can set me straight.
While running, it periodical makes a groaning noise
and squirts fluid out the mounting flange below my right knee; that is the flange for the lines to/from the pump. It is blowing fluid all over the console, battery etc. Fluid is whiteish and most likely needs changed out. What cause the pump to grain and pressureize the lines every minute or so?? Thank much in advance
d
