Re: Stuck pressure plate on IHC 350
Posted by Andy Martin on October 22, 2000 at 13:36:45 from (38.31.74.105):
In Reply to: Stuck pressure plate on IHC 350 posted by Paul S on October 22, 2000 at 12:31:37:
You can start it with the transmission in neutral.
Sometimes a little heat and vibration will loosen a frozen clutch. After you run it for a while you might try pulling it with the engine off and trying to work the clutch free.
But in all likelyhood you will need to get the clutch out. After they are unstuck they often don't last long because the clutch material has stuck to both the flywheel and pressure plate and wears away quickly.
Post A Followup
: Re: Re: Stuck pressure plate on IHC 350
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
