Re: Re: Stuck pressure plate on IHC 350
Posted by Paul S on October 24, 2000 at 15:41:10 from (204.186.42.73):
In Reply to: Re: Stuck pressure plate on IHC 350 posted by Andy Martin on October 22, 2000 at 13:36:45:
Thank you Andy for your advice. Best wishes
Post A Followup
: Re: Re: Re: Stuck pressure plate on IHC 350
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
