Assuming the wiring is OK, could be the diode has failed open. Try shorting across the diode and see if it now charges. If so, replace the diode.
If it still does not charge, bypass the internal regulator by shorting the test tab inside the D-shaped opening in the rear of the alternator to ground (photo). If it charges hard with the tab grounded, the VR has failed - a new VR or replacing the alternator is the fix.
However if it doesn't charge with the tab grounded there's something else wrong with the alternator. Best solution is replace with a rebuilt alternator.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only
... [Read Article]
Latest Ad:
[More Ads]
