Sleeve Removal Puck Sizes
Posted by equeen on November 16, 2012 at 09:31:09 from (209.102.248.236):
I have an opportunity to have a few sleeve removal pucks made at a very reasonable price. I'd appreciate help regarding dimensions.
It appears that the block bore and sleeve OD at the seal for two engines I'm working with at the moment is 3 7/16 (3.4375).
Question 1: What should be the "outer" diameter of the puck?
Question 2: What should be the "inner" diameter of the puck for:
3 1/4 bore sleeves?
3 1/8 bore sleeves?
3.1875 bore sleeves?
Question 3: How thick should the "steel" puck be from the bottom of the puck to the cut for the "inner diameter" of the puck?
Thanks.
