Re: Sleeve Removal Puck Sizes
Posted by El Toro on November 16, 2012 at 10:22:26 from (108.3.143.30):
In Reply to: Sleeve Removal Puck Sizes posted by equeen on November 16, 2012 at 09:31:09:
You may also need the measure the block so the outside diameter of your pucks will clear the block. If the bore diameter on the sleeve is 3.00" at the seal under cut the puck to 2.990" to 2.987". On the 3.125" bore undercut puck to 3.115" to 3.113" and on the 3.1875 bore undercut to 3.1865-3.1863". Since these sleeves are probably worn, a .010" undercut on the puck should fit easily into the bore of your worn sleeve. Hal
