hand crank?
Posted by mschwartz on November 16, 2012 at 19:17:38 from (216.163.99.163):
Could anyone tell me if the starting cranks were the same for the F-series tractors and the farmall H and M? I know that some were longer for the wide front axle. Mostly wondering if the slot in the end for the starting pin coming out of the bolster was in line with the bend in the handle or was 90 degrees off? Have some that are both ways but not sure if they have been modified or not. Thanks, Mike
