Posted by Janicholson on November 17, 2012 at 11:24:31 from (96.24.99.126):
In Reply to: hand crank? posted by mschwartz on November 16, 2012 at 19:17:38:
I can give an answer that works!! When put on the crank drive, and pushed in to engage the crank, the handle of the crank should be at the bottom, or 15 to 20 degrees clockwise from bottom. (assuming the engine was shutoff and allowed to stop naturally) inline 4 cylinder engines stop with the pistons about 1/2 way in the bores. Pulling up is the only safe (ish) way of cranking, and if the pin placement was incorrect, the handle would be in an unsafe position. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
