Ammeter Suddenly Shows Charging
Posted by F4RM@11 on November 17, 2012 at 14:35:13 from (50.126.213.255):
After getting the SM started again following a carb rebuild, I turned to the electrical system to troubleshoot the lack of charging. The VR output had been adjusted and the gen inspected by an auto electric shop - both had a clean bill of health.
The ammeter showed a slight discharge with the ignition switch on and the needle didn't move with changes in engine speed. Following Bob's troubleshooting flow chart, I made it through to the last step before the ammeter began showing a charge.
When I jumpered the BAT and GEN terminals at the regulator, the ammeter suddenly began showing a charge and continued to do so afterward. The needle moved appropriately with engine speed.
I'm curious as to why a charge on the ammeter suddenly began to show after making this brief circuit. The battery was fully charged after I returned to the shop as the trickle charger indicated so.
