Farmall A Oil Filter (short or tall)
Posted by Stevie J. Mote on November 18, 2012 at 14:03:08 from (173.55.14.150):
Hello. I measured the height on the Oil Filter on my 1945 Farmall A. The measurement is 5 1/2" tall. So would this be the short or tall filter. I know that the taller was also used on the Super A. What year did they make the change. THANKS
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
