350 IH power Steering
Posted by MN Red on November 18, 2012 at 18:40:43 from (216.66.73.62):
I am adding the torque amplifier (behlen the one that mounts in the steering shaft) to a 350 that is not a factory P/S I didn’t move the flow divider over to the new tractor. I know you can buy an aftermarket flow divider. I will not use the hydraulics for any other reason but P/S. My question is if I run the hydraulics through the torque amplifier and then to the hydraulics system will it be ok or will it damage the amplifier or give other problems? Thanks
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
