Re: 350 IH power Steering
Posted by D Slater on November 19, 2012 at 00:17:01 from (184.15.8.142):
In Reply to: 350 IH power Steering posted by MN Red on November 18, 2012 at 18:40:43:
Torque amplifier is not the correct name for the behlen unit. Think you probably have a farmall 350 tractor and you are getting answers for a IH utility.
If you have a valve set to double acting with the operating handle tied or blocked to deliver constant pressure, and run its pressure outlet to the steering unit and the return to its other outlet it will work. Don't know if it would give any problems for long term use. Saw one of those units mounted on a H one time and they were running it straight off the transmission driven hydraulic pump. No move no PS.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
