super m belly pump control rod
Posted by jimmy green on October 23, 2000 at 20:39:08 from (63.16.103.21):
On my super m the hydrolics won't hold unless I hold the rod up off the stop about 1 1/2". I tried to adjust by moving the lever on the valve shaft but that didn't work. I've ended up bending a bow in the control rod to,in effect, make it shorter. What is my solution? (1) shorten the rod by cutting it off and re-bending the end at the control lever? (2) remove the stop pin and re-weld it 1 1/2" lower down on the rod? Or is there a internal adjustment to the valve that I can make? Any suggestions would be a big help. My service manual doesn't mention anything about any adjustments that can be made.
Post A Followup
: Re: super m belly pump control rod
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
