Re: super m belly pump control rod
Posted by Garnet Best on October 24, 2000 at 18:26:07 from (142.177.60.115):
In Reply to: super m belly pump control rod posted by jimmy green on October 23, 2000 at 20:39:08:
Jimmy
I suspect your problem is inside the belly pump. There is a lever clamped on the shaft inside which activates the valves. Sounds like it has slipped or is misadjusted. You have to drop the unit out (careful that sucker is HEAVY)and remove the rear cover to get at it. Takes a little maneuvering to get the cover off as the lever has a tab in a slot on the next lever. You will recognize it when you get it apart. The tricky part is getting the thing back together as the lever tab must go back in the slot on the next lever. Takes a lot of patience and more than one try. By the way that cover comes off with the pump attached so you do not have to pull the oldham coupler or worry about the shaft seal. Good Luck.
Post A Followup
: Re: Re: super m belly pump control rod
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
