Re: Farmall A 3 point hitch??
Posted by gene bender on November 21, 2012 at 08:06:00 from (207.177.56.85):
In Reply to: Re: Farmall A 3 point hitch?? posted by DeltaRed on November 21, 2012 at 06:58:09:
You dont change timing cover ect on the A. Easiest way is run a pump off the belt pulley drive then build a nice 3-pt. You can also run a pump off the gen drive if you think you have to have live hy. Makes a nice compact set-up running off the belt pulley res under the seat and control either side of the seat unless you want to run hoses or tube all over the tractor.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
