Alex,you will need a hydralicpump,timing cover,gears,etc.Then you will need to find a lift all unit that sits under the gas tank.Going to be EXPENCIVE.Better to buy a complete SA,or at least a parts SA and do some swapping.The easiest way is to find a power steering pump from a junkede truck. belt drive off the frontof the crankshaft.Get a spool valve to control it.One thing nobody has mentioned is a rockshaft assy.SA has that.A does not.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
