Posted by shakin not stirred on November 22, 2012 at 05:39:07 from (67.241.169.164):
Got my F-12 running a couple of weeks ago. Engine was loose, rebuilt magneto, carb, fuel pump, new spark plugs, magneto timed, set valve lash hot, points set to .013", spark plugs gapped, etc. Ran great for the first few hours, but now it loses power going uphill and shakes at higher rpm. Adding choke for more fuel does not help. The shake at high rpm also happens when out of gear and also when clutch is pushed in so it's in the engine. idles just fine and got spark to each cylinder and no exhaust smoke. I'm out of ideas and would appreciate any thoughts. thanks!
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
