Posted by Janicholson on November 22, 2012 at 06:56:36 from (96.24.99.126):
In Reply to: F-12 power loss and shake posted by shakin not stirred on November 22, 2012 at 05:39:07:
Try this simple test. Pull off each spark plg wire at the plug and use a cloths pin to clamp them so there is a 1/8 gap between the clip and the plug tip. This causes the voltage to go up and partially fouled plug to fire. (easy to try, and indicates the need for cleaning the plugs.) The newly started tractor could be causing that.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
