Re: Question for you diesel guys
Posted by Bob M on November 22, 2012 at 12:26:57 from (69.207.86.27):
In Reply to: Re: Question for you diesel guys posted by John in Pennsylvania on November 22, 2012 at 12:08:57:
Pump drive key sheared I suppose is possible (I've had the camshaft key break on a gas tractor).
Is there a timing adjustment on your pump like on the MD/WD6/WD9 pumps? If so you can change the timing using the adjustment. Otherwise you might set the pump timing 1 tooth advanced from the factory timing mark and see if this helps.
Unfortunately I'm not familiar with the BD 154. Does it have a Roosa Master pump, or ????
