Re: Power Steering Compatibility
Posted by D Slater on November 24, 2012 at 07:58:11 from (184.15.8.142):
In Reply to: Power Steering Compatibility posted by Dude with a 300 on November 24, 2012 at 06:25:33:
Steering worm shaft will be different and the supports to keep the unit from rotating is different. You can cut the existing shaft and put a keyway in it and make support straps or find the original parts. Like the other poster pointed out if running it from the existing hydraulics you need to get all the parts.
Unless you know it was a working unit it may save some trouble to run it from a separate engine driven pump.
This post was edited by D Slater at 13:01:01 11/24/12.
