Re: touch control cylinder head
Posted by Harold Hubbard on November 24, 2012 at 13:41:25 from (205.209.16.24):
In Reply to: touch control cylinder head posted by joshua rod on November 24, 2012 at 13:02:34:
Probably the last guy glued it on really well, so it wouldn't leak. If you have all the bolts out, you just have to abuse it until it comes off. Try a soft hammer against the sides of it in all directions. Try some heat, heat gun not a torch, unless you are very careful. Last resort, a thin wedge at each corner, then progressively thicker ones when it starts to move. You will probably wind up splitting the gasket, with part of it on the head, and the rest still stuck to the block. Try to keep all the metal damage on the outside half inch of the surfaces, and smooth it up before reassembly.
