I'll have to get a compression tester, I've misplaced mine, years ago... and see what I have.
I figured since it worked last week, and didn't yesterday, and I've been meaning to give it a tune up before winter so it starts better, I'd start with that, figuring one of the plugs or wires gave up since they were past being replaced.
It's probably time to bite the bullet anyway and rebuilt the head, finally get some unleaded valve guides in it, etc. The oil running/seeping out the bottom of the intake manifold port is really bothering me... something is worn out up there...
I didn't know if someone would know what that might be???
Heck, it might not even be related to the cylinder not firing, that could be a separate issue like the intake valve not opening because something broke. If something was stuck open, I'd expect backfiring if the exhaust was stuck open or messing up the other three's running if the intake was stuck open.
odd... but I guess I'm actually more concerned with the oil seep from the intake manifold than the cylinder not firing.
thanks,
mark
This post was edited by scruffyia at 15:35:56 11/25/12 2 times.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
