that oil is due to cyl. not firing as i suggested.you have a bad valve, no compression on that cyl. that cyl's valves has nothing to do with the other cyl's running. i am leaning to the burnt valve cause they cant be stuck if you say you use the tractor. so check compression then tell us what u find. also can hear a burnt exhaust valve, and thats the ones that burn first. i would not even worry about the compression tester. just hold your thumb over hole while cranking cause there would be no compression to even blow it off. then you know its tear down time in a hurry.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
