Re: Farmall 140 Charging Circuit
Posted by Bobinva on November 27, 2012 at 11:03:10 from (108.48.43.190):
In Reply to: Farmall 140 Charging Circuit posted by BillyHooper on November 27, 2012 at 10:06:00:
The internal regulator is probably the issue...I had a Focus that the battery died on...I thought it was the alternator had quite working..just the opposite. The regulator went haywire, and the unit was putting out 19 volts instead of 14.5 or so...have that unit redone and you'll probably be OK... I've got a '74 140 with a 12 volt generator that charges just fine...hope it continues... Bobin VA
