Farmall 140 Charging Circuit
Posted by BillyHooper on November 27, 2012 at 10:06:00 from (64.253.216.185):
third party image
Installed new Delco alternator on '76 140. Charging voltage seems high, 15.4 Vdc at battery terminals. After extended use the battery got hot and began to smoke. No 'external' voltage regulator visible anywhere. Is regulator internal to alternator? See picture link below. Left wire on resistor was disconnected to prevent further charging until problem is found. Any suggestions on how to correct overcharging problem?
