How is the resistor connected into the circuit. Appears to be a resistor used in coil circuit and should have nothing to do with the alternator and is not normally mounted on or near the alternator.
By chance is the #2 wire on the edge plug on the alternator which is cut off on right edge of the picture the same wire that connects back to the right side of the resistor. Where does wire on other side of resistor go? If this side of resistor was connected back to battery source it could drop the voltage at pin 2 causing the sensing circuit in the regulator to see a supposed low battery voltage and increase the voltage output to make up for it.
If this is the case, eliminate the resistor and connect as Janicholson indicates and see if this solves the problem
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
