Dump valve LIGHT?
Posted by Altmodisch on December 02, 2012 at 07:37:16 from (69.21.233.4):
I don"t have orginal gauges in 706 due to a fire all gauges were replaced with 2" manual gauges and the dump valve switch has no wire to it. So I need to figure out a system for the light.
I need to run a wire from key to an ungrounded light and a wire from the light to the dump valve switch so when the valve( opens?) it grounds? and turn the light on correct? in order to set the dump valve.
