Installing SM Pressure Plate Question?
Posted by pete_5959 on December 02, 2012 at 12:03:59 from (70.63.206.178):
When I disassembled the clutch assy there were flat washers cut on one side that were installed between flywheel and pressure plate. I have the new clutch reinstalled but was looking over the parts diagram and these washers do not show? Are these suppose to be installed? Thank you.
Pete in NC
