Re: H axle and cover back on.
Posted by sflem849 on December 03, 2012 at 19:39:29 from (69.197.84.39):
In Reply to: H axle and cover back on. posted by jbp on December 03, 2012 at 18:28:40:
I did it a couple years ago to my H. It isn't too bad. It is a lot nicer than dealing with your problems!!! That would drive me crazy.
You can check out the project here. http://photobucket.com/FarmallH
A couple highlights.
third party image
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
