Re: 1947 H light switch wiring
Posted by Janicholson on December 03, 2012 at 20:02:05 from (96.24.99.126):
In Reply to: Re: 1947 H light switch wiring posted by Frankenford on December 03, 2012 at 15:34:39:
One item needing mention the dim position works by placing that wire wound resistor in series with the lights. It is powerful (able to dissipate) enough to work with the original headlights. If you put bright lights in it that draw even 20% more than the original lamps (about 7 amps or so) the resisor will glow then blow. One way to manage this is to use relays to control the lights. using the original switch would require your removal of the wire wound resistor to gain access to both the H (full output) terminal, and the D terminal (Dim) so that two different relays can power differing setups of lamps. If only bright is needed, disconnecting the resistor may be needed to avoid the glowing resistor. Jim
