Re: WooHoo! H hydraulics work!!!
Posted by CNKS on December 07, 2012 at 07:12:22 from (216.144.104.128):
In Reply to: Re: WooHoo! H hydraulics work!!! posted by MisterT on December 07, 2012 at 06:35:08:
"303 fluid is a generic equivalent of Hy-Tran". Probably better, 303 is equivalent of SAE 20, Hytran is equivalent of SAE 10. 30 weight engine oil may be better for that provided the tractor is not sharing implements with a tractor that uses hydraulic fluid. Not sure about the non detergent as we used detergent oil in my dad's H in the 50's -- heavy use, detergent worked fine.
This post was edited by CNKS at 07:14:20 12/07/12.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
