Re: WooHoo! H hydraulics work!!!
Posted by Duner Wi on December 07, 2012 at 10:41:54 from (216.226.80.242):
In Reply to: WooHoo! H hydraulics work!!! posted by Dan-in-MO on December 06, 2012 at 20:47:49:
What diameter cylinder do you have? Thanks.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
