WooHoo! H hydraulics work!!!
Posted by Dan-in-MO on December 06, 2012 at 20:47:49 from (64.134.123.252):
I posted some time back about running a log splitter off my belly pump. Well, I finally got all the hoses connected, the return line fitted to the filler/breather and the valve on the splitter hooked up. Gave it a try today and sure enough, works like a charm. I suppose that old pump hadn't been used very much over the years.
Now for a question. I filled it with 303 hydraulic fluid, then read somewhere online that I shoulda used 30wt motor oil as the hydraulic fluid is too thin and will leak out of the pump. Any truth to this?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
