Re: WooHoo! H hydraulics work!!!
Posted by Paul from MI on December 08, 2012 at 18:39:02 from (204.106.250.243):
In Reply to: WooHoo! H hydraulics work!!! posted by Dan-in-MO on December 06, 2012 at 20:47:49:
I have been using a home made splitter powered by the hydraulics on my JD A--at about 1000psi-- for the last thirty-five years. I run a 4" cylinder and it works fine, maybe I get 3-4 pieces a year that I can't split. I split about 12-15 cords a year so not too bad. Bet the H will do as good.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
