Re: Frontend Loader on a 444 international
Posted by jimb2 on December 08, 2012 at 20:27:45 from (174.114.182.155):
In Reply to: Frontend Loader on a 444 international posted by Dlong on December 08, 2012 at 17:16:32:
Hi Darryl, usual hookup was to cut the pressure
line going to hydraulic reservoir in front of the
left brake pedal. At one time IH had a kit with 2
replacement hi pressure lines that replaced the 1
solid line and you connected in and out of loader
valve to the ends of these lines. So loader valve
in from pump side of cut hi pressure line, out to
hi pressure line to hydraulic reservoir and dump
from loader valve to pipe T into hydraulic
reservoir filler plug.
JimB
