Jim when ya adjust therm valves on them you remove the timing cover on the bell housing and reinstall the timing pointer with the two cover bolts , then ya set it at TDC and you are either on #1 or #6 and if both valves are loose on either 1 or 6 you are at TDC on that hole . Then ya adjust as stated in the book , then ya roll her over a full turn and adjust the other 6 and easy way to keep track is with a crayon and just mark the valves as you do them. And here again you MUST look at the rocker arm for ware and only get the feeler gauge under the worn part of the rockerarm or your valve set will be off. As to doing them HOT anything over 70 degrees is good. For the most part people think that i do not have to adjust valves anymore because we don't have to on our cars and trucks. Wrong . Any engine with solid or rollerized cam followers needs to be adjusted , Even the Dodge Cummins needs adjusted and by my book at around 25000 miles . My own 806 was never done till a few years ago when i pulled the valve cover and had to use a gskt scraper to break the org gskt. I check the valves on it around 1500 hours or around every three years.On my Dodge with the Cummins with the miles i put on it that is about once every four years. No on the gassers they get the valves run each year in the spring when i do the tune up along with checking the ing. timing when i put the new points in.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
