Re: setting valves on 806D
Posted by Janicholson on December 10, 2012 at 20:24:21 from (67.72.98.45):
In Reply to: setting valves on 806D posted by jdetig1 on December 10, 2012 at 17:26:15:
Heat is the answer. Is the fuel Winter blend? Are the batteries cranking it like 12.6 volts, or like 10 volts? Slow cranking is a real issue.
An engine block heater (tank type or core plug style) on a timer to give it 2 hours of warming before depending on it is pretty much normal. If it is using oil, or down on power, it just might be tired (as Tractor Vet points out) Ether is hard on them, you are correct. here is a bit of valve adjust thinking:
Valve Adjust by Jim --- It is simple and fool proof. The process works for all engines with adjustable poppet valves and any number of cylinders. Identifying the valve order is all that is necesary (given in this pprocess for the IH 6 cyl).
I do it this way others do a different system. It must be set cold first, so setting it twice (or once) is normal Get the specification.
Set the intake valve on cylinder #1 (Front) when its exhaust valve just starts to open.
Set the exhaust when the intake just closes.
These are the two positions that can be seen at the springs and retainers for each cylinder to be as far away from a lobe on the cam as possible while still knowing where it is.
The order is (front to back EI-IE-EI-IE-EI-IE)
Look at #1 valves, Turn the engine till the Exhaust just starts to begin opening (moves) then adjust the Intake valve. Rotate more until the intake just stops moving after having been open) and adjust the exhaust. Treat every cylinder (pair of valves shown above) the same way, remembering they switch places between cylinders) I put a rag over the ones I have done to keep track of progress, and avoid mixing what I am looking at. Jim
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
